WSN application
Hello
Does anyone know how I can use the WSN Host API components in the picture in Labview to transfer a message from a en end node to the gateway via a router node (using a cluster or mesh network topology) ? I've tried binding them in different ways and none of them worked.
Thank you !
(4,124 Views)
I don't know if this triple post was an accident, but I'd say to keep the discussion in one, thread, preferably this one.
http://forums.ni.com/t5/LabVIEW/WSN-application/td-p/31292
(4,111 Views)
Hi kaoutar!
Is there a special reason on why you want to use the API to send data instead of the simple I/O Variables to send information from the nodes? The API is more intended to monitor and programmatic control of the wireless nodes from the host side.
AGJ
(4,083 Views)
Hooovahh I apologize, I shoudl have taken a look on the rules befor, thank you sir!
(4,053 Views)
agjcr,
i didn't know actually which one is more effecient, so I'm working on both, and unfortunately I couldn't make none of them work, for the I/O method it s almost done, all I need is to figure out how to configure the variable in "capture1" as a shared variable in "capture2", I have already asked this question in the forum, but i guess I wasn't clear as I should have been.
(4,047 Views)
Hi Kaoutar,
I might be missunderstanding what you mean be configure the variable in capture 1 as a shared variable in capture 2. If I understand correctly you want to change the indicator in capture 2 to be a shared variable and connect to that shared variable from capture 1. To do that you should just be able to drag and drop the shared variables from your project into your VI. You will then maybe need to change the access mode to write and you will be able to write to the shared variable.
I hope this helps!
Scott B.
AE NI
(4,010 Views)
