WSN Output
Good morning,
Is it possible to resolve a complaint? I have a hardware designated WSN andWSN-9791-3202, is now all set up.
I can read voltage values​​, but can not control my digital outputs, I intend to getthrough a boolean voltage of 12V.
For this application it is necessary LabVIEW WSN Pioneer? Or just be able to runwith LabVIEW?
Thanks in availability.
regards,
Hugo Santos
Hugo Santos
Student at ISEC - Master Mechanical Equipment and Systems
(2,375 Views)
Hi Hugo,
thank you for using NI discussion forum.
All will depend on the needs of your application : with the NI LabVIEW Wireless Sensor Network (WSN) Module Pioneer it's easier to customize the node behavior, battery life is extended, and performance are better on analog and digital input.
You can find more information about this module here:
http://zone.ni.com/devzone/cda/tut/p/id/9006
I'll see you on your second forum (https://forums.ni.com/t5/Wireless-Sensor-Networks/How-to-control-the-output-voltage/td-p/1956057).
(2,328 Views)
