WLS 9205 setting input voltage range
Hi folks. I need some assistance in setting my input voltage range for my WLS 9205. There are three settings (it would appear) from the documents supplied with the DAQ device ranging from +/- 200mV, +/-1V and +/-10V. How can i create a dynamic menu in standard Labview to alter the settings within a .vi. I am not using field point or anything of the sort.The DAQ mx does not give me the option to select the range either.
On the old devices, you could alter setting using dip switches but there are no dip switches on this device. Any advice would be greatly appreciated.
Daragh
(2,804 Views)
Hi Daragh,
Thank you for posting on our forums, I will be looking into your query. What exactly are you trying to change, the input voltage range?
If so then this is the KnowledgeBase article you are looking for!
Many Thanks,
John McLaughlin
Academic Account Manager
National Instruments UK & Ireland
(2,794 Views)
Here is the equivalent information for NI-DAQmx (since the WLS-9205 does not use LabVIEW FPGA):
Using Min/Max or High/Low to Set NI-DAQmx Channel Gain
Brad
Brad Keryan
NI R&D
(2,787 Views)
