Voltage Pulse to RPM
I have a speed sensor that senses a notch in a motor shaft.  When the notch is sensed, a 5V voltage pulse is sent to my NI cDAQ-9171.  Does anyone have a good idea how to program LabVIEW to convert that 5V voltage pulse into a RPM measurement?
Message 1 of 16
(8,541 Views)
You could use peak detection, then convert the time to rpm.
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
Message 2 of 16
(8,539 Views)
Could you provide a sample code?  I understand what you are saying, I am just having difficulty seeing the program
Message 3 of 16
(8,533 Views)
NI cDAQ-9171 is 'NI CompactDAQ 1-Slot USB Chassis', what I/O module are you using for your application?
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 4 of 16
(8,530 Views)
I have a NI 9923 connection for a 37-pin DSUB module
Message 5 of 16
(8,521 Views)
This is also not an I/O module, but this is just a Front Mount Screw Terminal Block for 37-Pin D-SUB Modules.
Message 6 of 16
(8,519 Views)
NI 9207
Message 7 of 16
(8,517 Views)
Here is the code that I have started.
Message 8 of 16
(8,503 Views)
Ok, so you're using an analog input module.
1. Calculate the frequency of acquired signal (in Hz).
2. Multiply it with 60 and thats the RPM.
Message 9 of 16
(8,500 Views)
Yes, I agree. My question really is how do I obtain the frequency?
Message 10 of 16
(8,498 Views)
