07-08-2016 02:24 AM
I'm having issues with placing a mean block on the output of a DAQ assistant. I have seen this done on a video and copied it exactly although for some reason I am unable to make the connection as "the sink is void" e.g. the mean input is void. I have attached a simplified example of my VI to highlight the issue. Thanks in advance.
07-08-2016 02:34 AM - edited 07-08-2016 02:34 AM
Hi
I tried open your attachement in LV2015 and it displayed error as you mentioned and i clicked some where in block diagram and the error got solved by its own
with pallete "convert from dynamic data"
i saved the same and i opned again the issue was not replicated
Hope you need to use coversion pallete to solve the issue as tge input to mean is Numeric array.
07-08-2016 02:39 AM
It doesn't seem to want to fix itself. Keeps telling me that im trying to connect dynamic data to void but doesnt do anything about it and convert the data. And when I put the conversion in manually it messes up the rest of the program. In another program I have the mean worked fine and fixed itself like you say, although in this case I'm having no such luck.
07-08-2016 02:48 AM
Are you using same version in both scenario (Working code as well as Problematic code )
07-08-2016 02:52 AM
Yeah both are the same version. It just doesnt seem to want to auto fix the data conversion.
07-08-2016 03:10 AM
Could you attach your corrected version of my VI so I can try and deduce the issue?
