Voice Recognition Via Internet
Dear Friends,
I am very interesting in the application which user can monitor and control the VI via Internet. In this case, we can apply remote pannel on server side and http in the explorer
with the run-time engine on the client side. This method is succeeded to control the VI via internet.
But I would like to control the VI by Voice command via Internet. Is it possible to create such VI according to the software limitation in LabVIEw 7?
The following applications will be applied in my VI....
1. LabVIEW 7 Express
2. Microsoft Speech SDK
3. Microsoft Agent
4. Add on??
I am looking forward your kindly suggestion to create such VI....
Thanks in advance.
Jo
AU, BTL
Ba
ngkok, Thailand.
(2,851 Views)
I do not think you will be able to use remote front panels for this application. There is no way to input the voice into the web browser running the panel.
You might instead consider writing VIs that communicate over the internet. It is not as flexible as the remote front panels but it gives you a way to access the local hardware (like the sound card), transmit to the server, and recieve information from the server. Of course, you could just put the voice processing code completely into the remote application.
Good luck with your project.
(2,851 Views)
Thank for your kindly suggestion.
But Kyle said that it is possible as he mentioned in the following link...
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000EEAA0000&UCATEGORY_0=_15_&UCATEGORY_S=0&USEARCHCONTEXT_QUESTION_0=voice&USEARCHCONTEXT_QUESTION_S=0
Jo
(2,851 Views)
