Vivado 2013.4 compilation error
Hey Amuri,
How often does this error occur? Is it intermittant, or does it happen every time you try and compile? Are you trying to compile multiple FPGAs in parallel?
Applications Engineering
Message 11 of 16
(837 Views)
Yes, it happen all times. I almost give up using NI. I have three FPGA VIs for my three MyRios in my system.
Message 12 of 16
(834 Views)
Long shot....
If you have a clock constraint for a custom CLIP which links to a clock you're actually NOT using in your design, it can lead to this error.  I have run into this int he past and it took me a while to find out where the problem originated.
Low chance of being correct, but in the absence of other alternatives....
Oh, actually, forget that, I see your error occurs at the Generating IP stage....
Message 13 of 16
(829 Views)
Hey Amuri,
Feel free to provide your FPGA VIs if you'd still like to investigate this issue and we can see if it's something with those. Do you get the same behavior with trying to compile a new/mostly blank VI?
Bdog
Message 14 of 16
(823 Views)
Bump again
Message 15 of 16
(810 Views)
isaacvega,
Are you having a similar issue? If it's the same, then can you provide us with your FPGA code, information about your environment, and the errors you're getting? Also, are you able to compile a mostly blank VI--maybe something that just adds two numbers together?
If what you're experiencing is different enough from the original post, I might recommend starting a new thread to get fresh eyes on it as well.
Claire M.
Technical Support
Certified LabVIEW Developer
Message 16 of 16
(799 Views)
