Visual Studio 2005 device command shell
Hi all: I have been trying to locate the Visual Studio 2005 Device Command Shell (DCS) for a couple of days with no luck whatsoever.  This tool is needed for the LabVIEW PDA Module. By any chance do you know where I can get it? Thanks!
(4,120 Views)
What is the version of your LabVIEW PDA module?
Will this link helps you in downloading?
(4,105 Views)
The version I'm using is 8.0.1
I tried that and many other links that points to the gotdotnet website. Microsoft has replaced the GotDotNet website with the MSDN Code Gallery and this tool is not available.
I've made a Google search and followed a couple of dozens of links with but in most of the cases they point to the extinct GotDotNet site. I wonder if someone that has installed the PDA toolkit for LabVIEW has this tool and could post it or knows where can I get it.
Thanks!
(4,095 Views)
Hello jrods,
I am not sure why this software is no longer available.  I am taking a look into it.  I will let you know as soon as I either find a copy of it, or have an explanation for why it is gone.
(4,076 Views)
Accepted by jrods
Hello jrods,
I am still having trouble figuring out where this software went and why.  However, I was able to find a place where you can download it here.  Hope this helps.
(4,043 Views)
Thanks much!!! I downloaded the zip file.
(4,034 Views)
