Padding String with 0's on the left - A better, Simple method?????
I'm looking to have the front part of an integer number padded with 0's.
I've attached a VI that works but it seems to be a bit more complicated than it needs to be so looking for a leaner solution if possible.
I've tried using the syntax formatting but wasn't able to get it to work.
The total width (with padding) should be 3 spaces.
Here are some examples of what I'm looking to do:
"1" should have an output string of "001"
"2" gives "002",   "99"  gives "099",  "100" gives "100",  "999" gives "999"
If anyone has any ideas I would appreciate the help.
best
SS
Message 1 of 19
(20,703 Views)
Hope this helps
Message Edited by TiTou on 07-03-2008 09:38 AM
Epictetus
Antoine Chalons
Message 2 of 19
(20,701 Views)
Smiley Very Happy
Smiley Very Happy
hahahahahaha....wow I feel like an idiot!
thanks for the help!!!!!!!
best
SS
Message 3 of 19
(20,692 Views)
No you don't :), we all miss obvious thing sometimes and it's being wise to go and ask someone else !
Epictetus
Antoine Chalons
Message 4 of 19
(20,689 Views)
Titou, I am tryng to print a 2D array (of strings) to a label.  Everything is ALMOST perfect, except that there is a tab issue (I beieve) that is throwing the top row (header information) off by one column (see screen capture).  I'm trying to incorporate a  Format Into String node to pad the values as necessary.  Not having any luck...can you point me in the right direction...PLEASE?
Message 5 of 19
(20,501 Views)
DanNatCorning, remove the Format into string, it is operating on the entire spreadsheet string which already has more than 30 characters.  Move the '%30s' into the format string of the ArraytoSpreadsheetString vi to pad the individual entries.
Message 6 of 19
(20,495 Views)
Darin, I feel like an idiot, but I certainly appreciate the help.  You made my weekend
Message 7 of 19
(20,479 Views)
Darin, I am still struggling with the correct format string.  I've tried 10 or 15, but I can't get the right combination to truncate the values to 3 decimal places, but space the column correctly too...can you help me out?
Message 8 of 19
(20,458 Views)
Look, you already have a 2D array of strings, and unlike numerics, strings have no special meaning for the decimal point.
You need to solve the problem upstream, when the relevant data fields are still numeric. Alternatively, you need to do some fancy parsing of the strings.
Can you attach the actual VI instead of pictures?
Message 9 of 19
(20,447 Views)
Also, please upload screenshots directly as PNG, JPG, or GIF files (NOT BMP). Don't embed them inside of Microsoft Word.
Message 10 of 19
(20,425 Views)
