Vision Assistant Crashes Vision Builder
Hi All,
I`m new to this forum so was unsure where exactly to post this so I took a gamble and selected here.
I have LabVIEW 2018, NI Vision Builder and Vision Assistant 2018.
Whenever I acquire an image in vision builder and then select the tab to edit this image in vision assistant, vision builder crashes and I get this error report attached.
I have completed numerous searches and have found discussion forums relating to this but cannot seem to get it sorted.
Any help greatly appreciated Smiley Happy
(3,082 Views)
You could try posting in the Machine Vision forum (listed under Most Active Hardware).  It would help to post more than a picture of an Error message -- perhaps code if you have it, or a detailed description of what you are attempting to do.
(3,066 Views)
Accepted by topic author jamescoady91
Hi James,
This is a known issue in VBAI 2018. Refer to this KB for a fix: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019ZZDSA2&l=en-US
This fix will be included in VBAI 2018 SP1 which will be released at NIWeek 2019.
Let me know if you have additional questions.
T. Le
Vision Product Support Engineer
(3,051 Views)
This worked perfectly thank you very much for your help! 🙂
(3,038 Views)
