Vision Aquisition Match Geometric Pattern
Hello there,
I have a problem with the match pattern things. Especially with the range settings there.
The options are Rotation Angle, Scale Factor and Occlusion. everything works except by Scale Factor.
When I turn on the Scale Factor my template will not be detected anymore at all.
My Template is a PNG-Data. Is maybe that the problem?
I use LabView20 (64-bit) on Win10
I try to do a selfdriving car on a trail "scanned" by a camera from the top and handled by a PID via Redlab.
On the car there is a "T" as a template for getting all position information.
If you need any more information just write.
Sorry for the bad english.
(1,421 Views)
Hi
Can you sent your application ?
bhovhann
(1,360 Views)
for sure I can.
(1,333 Views)
