Loop Controls[] of Cluster Inside Array without TypeDef Reference
i want to loop the Controls[] of a Cluster inside an Array.
i got it to work like this:
is it possible to loop the Controls without a separate reference/Control of my Cluster (in Sample called IconData)?
without this castido not get the Controls[] Property wich makes sense, since not every arraymust beof type Cluster but is there some Generic cast to Cluster wich would allow this code to work for every Array<Cluster>?
(1,787 Views)
Accepted by topic author PaulPascher
Sure. One general way is to drop a Class Specifier Constant from the Application Control palette, then click on the constant and navigate through the hierarchy to Cluster. Then, wire the constant to the Cast function.
Paolo
(1,776 Views)
