Visa error -1073807343 while using usb LED's
Hi All,
I am trying to communicate with LED hooked up to the usb , my vi works fine on one computer but gives me error on the another one( the other have the same configuration) the error I am getting is "-1073807343" can someone tell me what can be the problem. attached is my vi.
thanks,
AG
Message 1 of 10
(4,145 Views)
@AnkitG wrote:
Hi All,
thanks,
AG
Apparently it's not the same if you're getting that error.
Bill
CLD
(Mid-Level minion.)
Message 2 of 10
(4,098 Views)
Hello AnkitG
Could you explain a little bit more what you are trying to do? I don't seem to find the relationship between your VI and the question you posted. What
Message 3 of 10
(4,078 Views)
@WenR wrote:
Hello @AnkitG
Hi Wen,
The LED's are connected to usb to serial adaptor, and I want to find those LED's resource name using my vi to control them further in my program. while running the vi on a different computer I get this error i dnt understand, these led's just use rs232 connection I should be able to use the visa command to communicate .  but I get this error, I couldnt understand if this error is that it didnt find the LED's or something else.
Message 4 of 10
(4,070 Views)
What com ports are listed in MAX? How is this list different from your other pc?
Message 5 of 10
(4,062 Views)
Does the second computer have the drivers installed to make that USB-Serial Adaptor work?  You should see the COM ports show up in the Windows Device Manager and in MAX.
Message 6 of 10
(4,052 Views)
yes, i do have drivers installed, I am able to see in Ni-Max , i give visa resources name to the program. I also uses filter wheels
and while controlling or running the program I get this error(see attached)
Message 7 of 10
(4,041 Views)
Neither of those images show the error code that is in your first post. I'm confused as to what is actually happening.
Message 8 of 10
(4,020 Views)
Hi Dennis_Knutson,
those are the other 2 erros following the original " error -1073807343 "  , I checked the device manager the com ports are different , but I am feeding the main resource name directly to my vi's , also I am using .net library (provided by the hardware) which gives me error 1172   . net exception.
Message 9 of 10
(3,985 Views)
You can't get my name correct either.
Message 10 of 10
(3,976 Views)
