Virtualbench DIO
Hi.
I am working with Virtualbench. I want to program the IO's to four input and four outputs. I have tried to watch the example given by NI at:
https://forums.ni.com/t5/Example-Code/VirtualBench-Digital-Read-and-Write-With-the-DIO/ta-p/3996010
I have tested the example and from how I can see, it works as it defines all io's as output. If I apply any voltage to the inputs, the input Array Indicators does not change. If I remove the Virtualbench.dig.Write.vi in the program, the input array indicators is capable of seeing changes applied to the input channels. However, then all IO's are defined as inputs. I would like to have the inputs defined as above. Is this not possible?
\Morten
(2,773 Views)
You'll probably have a better response from the VirtualBench board - https://forums.ni.com/t5/VirtualBench/bd-p/340
You can click on options and request the moderator to move this.
(2,750 Views)
