VirtualBench with LabVIEW
I am currently trying to control VirtualBench with LabVIEW.
I have downloaded and installed VirtualBench Software (Ver. 19.0).
The documentation states that LabVIEW is supported by this software, but I cannot find where the VIs are located within LabVIEW.
How can I find them?
Are there any additional drivers or software that I need to install?
OS: Windows 11
LabVIEW: 2023 Q3
VirtualBench: VB8012-31067DC
(9,456 Views)
Accepted by S.Tsutsumi
NI has pretty much stopped supporting the VirtualBench since 2019.  But I created a NI Package just for this exact reason.  You can find it here: VirtualBench LabVIEW Drivers.  It uses the LVAddons folder, so it will automagically work for any LabVIEW version starting with 2022Q3.
Alternatively, you can use Digilent Waveforms.  There is a VIPM package that creates a LabVIEW palette for the Waveforms driver.
(9,447 Views)
Thank you for your quick reply. After installing the attached software, I was able to check VirtualBench's vi. Now it looks like I can control VirtualBench with LabVIEW. Thank you very much.
(9,428 Views)
