Virtual oscilloscope
I am trying to create a 4 channel oscilloscope using DAQmx functions. I have one quick question. Among my 4 channels, one is used for current and the other three are used for analog voltages. But the one I have created I used all the 4 channels for voltage. My question is how to make the 4th channel for current. I know I have to use DAQmx create virtual channel AI current, but how to use it together. How am I supposed to link three for AI voltage and the last one for AI current. If yes then how am I supposed to make single task out. I have attached the VI.
Thank you for your time.
(5,422 Views)
Hi lab,
use two calls of DAQmxCreateChannel, one for the voltage signals, the other for the current signal…
(5,411 Views)
thank you for your reply. How can I give all the channel as a single input to DAQmx timing and DAQmx Read. I am trying to create all the plot in single graph.
(5,399 Views)
Accepted by topic author bufferlab
Personally, I would make an array of clusters.  Each cluster contains the information needed for that channel (physical channel, type {Voltage or Current}, Max, Min, terminal configuration).  Then you can just use a FOR loop to add your channels to the task.  Each time you use the DAQmx Create Virtual Channel, that channel is added to the task.  So keeping the task in a shift register will allow you to add however many channels you need in whichever configuration you need.
NOTE: The case structure also has a "Voltage" case where the AI Voltage version of the Create Virtual Channel is used.  That first node is DAQmx Create Task.vi.
(5,379 Views)
can you please save the snippet in 2015 version. Thank you.
(5,369 Views)
Here you go.
(5,360 Views)
