Bug in right click menu for decorations?
I stumbled across something just now in LV 17 that seems to be a bug.  But a minor one in the user interface that hasn't seemed to cause any harm that I can detect.  I'm attaching a LV17 that demonstrates and includes the steps to witness it.
Basically I have two label decorations located on a tab control that I had selected together.  When I right click on them, the shortcut menu gives an option to "Change to Indicator".  That surprised me because I would have never thought to turn a label into an indicator.  If I just pick one label, or select multiple labels but they are set on the pane of the front panel, then this does not happen.  Clicking Change to Indicator seems to do nothing.  Upon further testing, this behavior occurred for other decorations like raised bevel boxes.
So something weird happens when multiple decorations that are rooted within a tab control causes the right click menu option of "Change to Indicator" to appear.
I just replicated it in LV 2014 as well.
Try it out and see if you have the same thing happen.  It seems like a bug.  But not one that causes any real problem.
Message 1 of 11
(4,380 Views)
2012 says "Change to Control". The bugs show no consistent behavior between versions.  Smiley Very Happy
aputman
Message 2 of 11
(4,373 Views)
In LV 2015 SP1 it thinks it's doing something, because the next time I right-click, it has the opposite.  i.e., if it was "Change to control" it's now "Change to indicator" and vice versa.
Bill
CLD
(Mid-Level minion.)
Message 3 of 11
(4,358 Views)
I also see the same behavior if you put the free labels into a cluster.
Bill
CLD
(Mid-Level minion.)
Message 4 of 11
(4,356 Views)
Actually, it does do something.  It changes the container they are in to whatever was specified, I guess the same way doing that to a control or indicator in the container does it.
The weird thing is that you can have controls and indicators on a tab control, so changing a control on that tab into an indicator or vice versa will not change the tab itself accordingly, but doing that with the decorations does!
So it is more than just amusing.
Bill
CLD
(Mid-Level minion.)
Message 5 of 11
(4,347 Views)
Which leads me to another observation:
There's an odd attribute of tabs where, depending on the number of controls or indicators you convert, the tab either becomes a control or indicator and I haven't been curious enough to learn the specifics.
Bill
CLD
(Mid-Level minion.)
Message 6 of 11
(4,332 Views)
You're right Bill.  I didn't notice that.  Mainly because tab control terminals are usually never connected to anything, I didn't notice it changed direction, and there were no wires that would thus break.
Message 7 of 11
(4,316 Views)
I only noticed it because I noticed it did that to the cluster I put them into.  I was curious about the tab control.  So chalk it up to another oddity about the tab control, and I'm sure someone will add that to the list of reasons they despise tab controls.  😉
Bill
CLD
(Mid-Level minion.)
Message 8 of 11
(4,308 Views)
I think you're right on your point about the cluster.  Both clusters and tab controls are types of containers, so there is a common factor there about these decorations being part of a container.  (I would have never stumbled across it for a cluster because I don't think I'd ever have a reason to put decorations in a cluster.)
If you can think of any other front panel elements that are containers, I can't at the moment, I'd be curious to see if the same thing would happen there.
Message 9 of 11
(4,303 Views)
I can't think of any at the moment.  And for me, placing decorations in a cluster is kind of an artificial scenario, also.
Now watch, NI will clean up the bug, then someone will lament that their favorite way of changing a cluster from a control to an indicator doesn't work any more.  😉
Bill
CLD
(Mid-Level minion.)
Message 10 of 11
(4,269 Views)
