Viewing and hiding plot channels
I've seen National Instrument's demo - Two Channel Osciloscope.
In this demo, they've used a case structure associated with what
channels to view (A, B or A&B).
However, I have 6 channels, on the same graph, and this method seems a
bit to awkward. I've tried accesing the channles using an attribute
node and then changing the color of the plot to the background color
so it won't show. This too sounds a bit strange, plus I could only
access the first plot.
Does anybody know of a better way to do it?
Shai
ps, please reply to shayv@hotmail.com
(3,520 Views)
Instead of setting the color to the background, you probably want to
set it to Transparent. This effectively hides the plot since nothing
will be drawn. To choose which plot to set, use the Active Plot
property. You will typically do this in a loop.
Make the top property
the Active Plot, grow the attribute node down and read or write the plot
properties below that. The graph will update at the end of each loop
iteration.
Greg McKaskle
(3,520 Views)
