Using <Ctrl + Up> as shortcut...?
I would like to have as a shortcut to one of my menu
items. The key combination is used in the Edit Menu to move around the
items in the the menu list but I'm unable to select this shortcut for
any of my menu items. Please advise how to make this work.
/Nimrod
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(3,146 Views)
The menu's built into LV are capable of doing typical key combinations, but
not all. If you want to get at other key combinations, you might want to
download the keyboard VIs from the NI ftp site or web site. They give access
to most keys and key combinations; so you can use them to catch the keys and
carry out the same action as picking the menu item.
Greg McKaskle
(3,146 Views)
