05-24-2015 07:38 PM
Hello all,
I have been learning on calling VIs dynamically and was wondering if there is a tool to view what VIs have been loaded into memory and their states. I know if I setup a project then in the Dependencies there will be Items in Memory which contains all VIs loaded, but most of the time I don't have a project setup.
I checked out VI Hierachy menu, it didn't seem to show when dynamic VIs were loaded. At the very least, I would like to see, say if I open the front panel of 5 VIs (not in run state), then the tool should show the names of those 5 VIs.
Thank you !
05-24-2015 08:36 PM
A project won't help you there, either. I don't think it can show dynamically loaded VIs, either.
05-24-2015 08:49 PM
I am pretty sure that Items in Memory of a project will show dynamic VIs. As I would look in there if a dynamically loaded VI got "stucked" and didn't exit properly.
All I was looking for is a tool to view what VIs Labview has loaded in its memory..?
05-24-2015 09:22 PM
Have you tried the Property Node App.All VIs in Memory? Drop a Property Node, choose Application, and look for All VIs in Memory. Does that do what you need?
05-25-2015 04:48 AM
If this is not what you're looking for, it's a good tool in itself and you can modify it to your need.
/Y
