Vibration analysis
do i need to double integrate the signal even if i get an accelorometer signal from NI sound and vibration signal simulator box ?
Message 31 of 37
(1,700 Views)
I wonder if by this time NI came with a vi that does just that gets in acceleration signal from a vibration sensor and provide as output the speed and the displacement. Anybody?
Thank you
Message 32 of 37
(1,691 Views)
You can use a straight accel signal for vibration monitoring and analysis - that is actually a common way to do such monitoring. Double integration would mean you transfer to the displacement domain. This is hardly ever needed/interesting as the higher frequency content is so strongly suppressed in a displacement signal.
What are you monitoring?
Message 33 of 37
(1,690 Views)
The Sound and Vibration Measurement Suited on-line manuals have some great tutorial information:
https://www.ni.com/docs/en-US/bundle/labview-sound-and-vibration-toolkit/page/user-manual-welcome.ht...
If you wish to purchase an excellent set of working sound and vibrarion measurement vis, with out of the box working examples for vibration monitoring, balancing, and frequency response, these are available as the Sound and Vibration Measurement Suite.  Otherwise, you can build up the functions you need in regular LabVIEW.  Following the concepts from the manual should be a big help.
Preston
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
Message 34 of 37
(1,686 Views)
I know. However, sometimes you just need it...
A lot of water went down the river since I started working more intesively with vibrations. I have a much better sense now.
Message 35 of 37
(1,685 Views)
Thank you, Preston.
I believe the "getting displacement from acceleration" vi should be in the basic set of tools.
Just a personal opinion.
Message 36 of 37
(1,684 Views)
i am doing this task using sbRIO9642 and sound and vibration signal simulator box  (in search of manual) on RealTime
control the harmonics of the vibrations obtained from the  sound and vibration signal simulator box
parameters:.... x and y acclerations from the box are obtained but  failed to  make the harmonic analysis
next tried to obtain the "TACH OUT " signal from the box so that i can measure the speed
i wanted to know  is tach out a digital or analog value and how should i count the number of pulses (implemeting a counter? or using a up counter)
and i also have tried on FPGA to do the same but unable to get the exact count value...
below are few codes which i tried on fpga
i am getting negative values in the count indicator...for the code integer.png
Message 37 of 37
(1,676 Views)
