Vi works in highlight execution but not in normal
There's something screwy going on here.  In your code, you set up VISA and enable termination characters, and specify SOH (when a more common sequence is <CR><LF>).  Then you show several examples of arrays of strings, with the final two strings being 0D and 0A.  What is curious about that particular string is that the normal EOL, <CR><LF>, when converted to a Byte Array of unsigned byte (there's a function in the String palette to do this) and expressed in Hex is precisely the array [D, A].
I wonder if "protocols" are getting mixed up, and what should be being output is a string (possibly with several components, possibly separated by, say, commas), followed by the normal EOL (also on the String Palette).  That makes more logical sense to me ...
Message 11 of 11
(274 Views)
