RUN TIME MENUS
para.pngI just started learning Labview. can someone give me a detailed explanation of how to solve the attached file? Thank you!
(1,164 Views)
You will need to create run time menu  including all these items , and based on your selection make like event structure that read the item tag you select from the menu and based on it the action will happen
CLA
(1,155 Views)
Accepted by topic author GaKEns
Hi Ga,
For item a you should use the menu entry Edit->RunTimeMenu…
For item b to d you should look at/into the example VIs coming with LabVIEW. There's an example finder in the Help menu…
(1,153 Views)
Thank you
(1,145 Views)
