Very large values from accelerometer
I did a small impact test in the lab, and recorded the acceleration. But I got very large peak numbers, like 300g, which is unreasonable. My vi has been checked by many people, seems like no problem. Does anyone have the idea why I got such big numbers?
Thanks.
Yuan
Message 1 of 17
(5,812 Views)
Yuan,
Why do you think the values you reported in your other thread are unreasonable? 200-300 g does not seem out of line for impact of one steel object against another.
What are the sizes and shapes of the objects involved? How is the accelerometer attached to the object? What is the range of motion and speed of the objects before impact? Is there any damping?
Lynn
Message 2 of 17
(5,808 Views)
Also, the material(s) of the objects.
Bill
CLD
(Mid-Level minion.)
Message 3 of 17
(5,779 Views)
If an object falls at 1m/s and is stopped over 1mm (little deformation):
s=v*t
v=a*t
v=a*s/v
a=v^2/s
a=1^2/0.001=1000m/s ~100g
So, how much deformation does two metal balls or two marble balls display when impacting?
It is good food for thought, as a rubber casing, adding just a couple of millimeters will do a lot for the G forces!
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 17
(5,743 Views)
Sorry for the delay. The speed of  the impactor is about 305in/s, and the impact duration is about 0.1s. The acceleration should be much less than 200g. In vi, I set the minimum and maxmium value as -250g and 250g, which are the measurement limits of the PCB accelerometer I used. This morning, I changed the range to -20g-20g, I got much smaller peak values, like from -25g to 25g. Then I found that every time when I tried to change the input range, my results changed accrodingly, the peak values are pretty much around the input range. Apparently, this is also not what I want. I was wondering why this happened?
Thanks.
Yuan
Message 5 of 17
(5,655 Views)
Can you double check your sensitivity and sensitivity units?
If you don’t have correct sensitivity value that would make big difference.
Hope it helps!
-lvABC
Message 6 of 17
(5,647 Views)
Hope it helps!
-lvABC
Message 7 of 17
(5,646 Views)
It would be helpful if you describe your hardware, DAQ , (signal-conditioner with setting) , sensor
and please post a link to the spec-sheet of the sensor and (if you have) the individual sensitivity (cal) value(s) of your sensor. (in metric if possible 😉 )
Now read the input voltage at a high sample rate (you can use one of the example vi's ) . If you have a pulse in the diagram hit edit-make current values default, save as a new vi and post that vi.
Greetings from Germany
Henrik
LV since v3.1
Message 8 of 17
(5,601 Views)
Yes, I double checked the sensitivity and the unit
Message 9 of 17
(5,544 Views)
Hi, Henrik,
The hardwire I am using is NI SCXI-1001, the module for accelerometer is SCXI 1531. I use DAQmx 14.1 version, the accelerometer is 353B01 from PCB.
The following link is the sepc-sheet of the accelerometer: http://www.pcb.com/Products.aspx?m=353B01, the individual sensitivity of the sensor  is 19.25 mV/g (1.963 mV/m/s^2). I set the sample rate as 10k HZ.
Please check out the attached vi.
Thanks.
Yuan
Message 10 of 17
(5,539 Views)
