Closing the command window after running .bat file using System Exec VI
Hello All:
I am running LV 2023 32-bit and I am having trouble closing the command window in LabVIEW using the System Exec VI.
Please see the attached pic for my settings.
When I double click the .bat file, after the file completes the window disappears.  I opened up the .bat file with Notepad+ and there is an exit command at the end of the program.   When I run it in LV, the window remains open and I have to type "exit" in the command window.
I found this knowledgebase article:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7lUSAS&l=en-US
In the article, solution number 2 states " use the command .com program with the /C flag".  I've tried different combinations to no avail.  Can somebody help me with this?
Thank you
(2,640 Views)
If you would lake to have command prompt closed when called program completed, may be more simple solution will be suitable for you:
(2,607 Views)
Typing the following at the prompt will close the Command Window:
  • Exit
Make a .Bat file using the Start for your LabVIEW program followed on the last line with the Exit command.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(2,555 Views)
Here is the .bat file with all the exit commands in red.  As stated, when I double click on this .bat file everything works great, the command window closes.  It's when I use the System Exec VI, I need to type "exit" into the command window to get it to close.  (I have wait until close set to TRUE)
@echo off
setlocal
setlocal ENABLEDELAYEDEXPANSION
REM Path to this batch script
set UNIFLASH_PATH=%~dp0
REM Path to DebugServer folder
set DEBUGSERVER_ROOT=%~dp0ccs_base\DebugServer\
set MODE=flash
set EXECUTABLE="!DEBUGSERVER_ROOT!bin\DSLite"
set GENERATED_COMMAND=-c user_files/configs/f28234.ccxml -l user_files/settings/generated.ufsettings -s VerifyAfterProgramLoad="No verification" -e -f -v "user_files/images/9675-1010-000 test2 20KHZ fan.out"
set ADDITIONALS=
REM list available modes
if "%1"=="--listMode" (
echo.
echo Usage: dslite --mode ^<mode^> arg
echo.
echo Available Modes for UniFlash CLI:
echo   * flash [default] - on-chip flash programming
echo   * memory          - export memory to a file
echo   * load            - simple loader [use default options]
echo   * serial          - serial flash programming
echo   * noConnectFlash  - bypasses connect sequence during flash; for programming a blank CC23xx device
if exist !DEBUGSERVER_ROOT!drivers\MSP430Flasher.exe (
echo   * mspflasher      - support MSPFlasher command line parameters [deprecated]
exit /b 0
REM no parameters given, use the default generated command
if "%1" EQU "" (
echo Executing default command:
echo ^> dslite --mode !MODE! !GENERATED_COMMAND! !ADDITIONALS!
echo.
CMD /S /C "%EXECUTABLE% !MODE! !GENERATED_COMMAND! !ADDITIONALS!"
exit /b !errorlevel!
REM user options parsing
set USEROPTIONS=%*
REM user options without the --mode
set "_args=%*"
set "_args=!_args:*%1 =!"
set "_args=!_args:*%2 =!"
if "%3"=="" (
set USEROPTIONS2=
) else (
set USEROPTIONS2=!_args!
REM custom mode from users
if "%1" EQU "--mode" (
set MODE=%2
set USEROPTIONS=!USEROPTIONS2!
REM default user options if none given
if "!USEROPTIONS!" EQU "" (
set USEROPTIONS=-h
REM mspflasher support
if "%MODE%" EQU "mspflasher" (
set EXECUTABLE=!DEBUGSERVER_ROOT!drivers\MSP430Flasher.exe
set MODE=
REM execute with given user parameters
echo Executing the following command:
if "!MODE!" EQU "" (
echo ^> !EXECUTABLE! !USEROPTIONS! !ADDITIONALS!
) else (
echo ^> !EXECUTABLE! !MODE! !USEROPTIONS! !ADDITIONALS!
echo.
echo.
CMD /S /C "%EXECUTABLE% !MODE! !USEROPTIONS! !ADDITIONALS!"
(2,499 Views)
Hello All:
I found a thread where somebody else had the same issue.
https://forums.ni.com/t5/LabVIEW/CMD-EXE-Output-Not-Showing-up/m-p/729103
Here is an excerpt from the author
"Long story short, the only feasible way I found to achieve the desired behavior is this:
Run System exec.vi with "cmd /c start batchfile.bat"
This allows you to view the batchfile's output (live) while also waiting for its completion in the labview code. The only drawback I see is that the terminal does not exit automatically when the batchfile finishes. To circumvent this issue just put an "exit" command at the end of your batchfile."
However, I DO have an exit at the end of my .bat file and the command window is still there 🤔
(2,528 Views)
Ah, OK, you would like to see live output. Then its corect, but you have to put exit at the end of called batch file, then it works, at least for me:
(2,504 Views)
