03-21-2018 07:07 PM
Has anyone tackled the problem of managing versions of packed project libraries? How can I ensure that the libraries being used by my application are the newest? How can I save and deploy libraries with the same name in a way that makes it easy to see if the correct version is in use.
With dynamically called libraries, I have put version numbers in the library name (since LV2015 this must be set before the library is built). With packed libraries that are dependencies, this is not an option.
Does one simply maintain a table of the most recent versions of the code in use and check against that?
03-22-2018
04:25 PM
- last edited on
04-04-2025
01:07 PM
by
Content Cleaner
Based on some research:
Hope this helps! Good luck!
Parul M.
Applications Engineer
