取消
显示结果
搜索替代
您的意思是:
Version Migration
已解决!
转到解答
@crossrulz wrote:
Jeff·Þ·Bohrer wrote:
Tim.  There is no version of device drivers that supports 2011 & 2017.
Just make sure you have the latest drivers for 2017.  The mass compile will handle the rest.
??? I may be learning something.  But, how can a mass compile fix code that was last saved in a version without device drivers support.
Perhaps, the vis were only on disc and not saved in the previous version after the new DDs were installed?
You are the master version conversion dude.  But I'd upgrade more often than every 6 years
"Should be" isn't "Is" -Jay
0 项奖励
21 条消息(共 22 条)
518 次查看
We already have a project that was written in 2011.  Those VIs use logical paths for any NI drivers pointing to <LabVIEW>\vi.lib or instr.lib.  So when you open the VIs in 2017, it will just point to the support VIs in the LabVIEW 2017 path.
22 条消息(共 22 条)
516 次查看
