Variant to XML parser to string
I am trying to trying to generate a data dictionary from a cluster using XML parser.  I am passing the cluster as a variant to LabVIEW's flatten to XML.
The variant timestamp goes in as:
14/08/1966 00:00:00
It comes out from the XML parser as :
<Timestamp>
<Name>PatientDoB</Name>
<Cluster>
<Name></Name>
<NumElts>4</NumElts>
<I32>
<Name></Name>
<Val>0</Val>
</I32>
<I32>
<Name></Name>
<Val>0</Val>
</I32>
<I32>
<Name></Name>
<Val>1976050800</Val>
</I32>
<I32>
<Name></Name>
<Val>0</Val>
</I32>
</Cluster>
</Timestamp>
How do I convert
1976050800
into year month day?
Seán
(4,398 Views)
Accepted by SeanJ
That's the number of seconds since LabVIEW Epoch Time.  You can convert this directly into a timestamp.
Bill
CLD
(Mid-Level minion.)
(4,389 Views)
That is the number of seconds since 01/01/1904 00:00:00.00 UTC.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(4,382 Views)
Thanks All,
In my defense I went to :
https://www.freeformatter.com/epoch-timestamp-to-date-converter.html
I was looking at Unix time!  Actually, this is indefensible Smiley Embarassed.  Thanks again,
Seán
(4,360 Views)
Instead of converting it to XML and parsing it, you could try using the "Data Type Parsing" functions (under the Variant palette) to gather the name, type and value etc.
(4,359 Views)
