Variable set point with real-time controller
Hi.  I want to create a real-time control module that has a time varying set point.  For each time step, I would like to read the value for the set point from an input file.  I am currently using the module found here as a starting point but I am not sure what I need to change the constant set point value to in order to read from an input file.  Any thoughts would be greatly appreciated.
(2,680 Views)
Afternoon Peckens,
Try starting with the following example to read in the data file (if it is a text file). Then you can use the iteration terminal of that loop to change the set point by indexing the array.
Read file
Kyle Hartley
Senior Embedded Software Engineer
(2,647 Views)
