VXI-11
Hi
I am trying to add Power analyser device in MAX, Via VISA TCP/IP ,but the Auto-detect option gives error(No devices found)
Veera
Message 1 of 9
(3,900 Views)
Dear Veeru,
This tutorial may help as a walk through:
http://zone.ni.com/devzone/cda/tut/p/id/3325
If you could also post a screen dump of your error that would be great to enable us to look into this further.
Daniel T
Account Manager
National Instruments UK & Ireland
Message 2 of 9
(3,878 Views)
Thanks Thomas
Actually i tried with that turorial page.
I have attached the error message
Message 3 of 9
(3,871 Views)
Dear Veeru,
Would you be able to provide more specifics of the Power analyser device? If you have links to data sheets or manuals for this device then that would be ideal!
Daniel T
Account Manager
Message 4 of 9
(3,853 Views)
Thanks Mr.Thomas
I have attached the User manual
Message 5 of 9
(3,844 Views)
Hi Veeru,
Can you "ping" the device that you are trying to connect from your local machine?
Andrew McLennan
Message 6 of 9
(3,821 Views)
Thanks Andrew
Yes,i can ping the device
Message 7 of 9
(3,817 Views)
I don't see anywhere in the manual that says the instrument is VXI-11 compliant. Are you sure that it is? Have you tried the Raw Socket communication option or the manual entry of a VXI-11 instrument?
Message 8 of 9
(3,805 Views)
Thanks Mr.Dennis
I tried the Raw Socket communication option, it adds the device in the devices & interface region in MAX but it shows some conflicts(may be i defined something wrong).
Message 9 of 9
(3,785 Views)
