VLC player streaming using labview
I am trying to create a vi to access VLC player using labview to stream .ts video file.
I am new to labview so I need help to achieve this.
Please suggest me to proceed.
Thanks in advance!
(5,754 Views)
(5,675 Views)
  • You can find the detailed streaming setting in VLC media player in the following link. External Link: Streaming HowTo
  • ​​​​​​The VLC media player is a free open source program and can be used to import dlls directly from LabVIEW. See the link: Example Program Draft of VLC RTSP streaming in LabVIEW
  • For the UDP protocol implementation in LabVIEW, refer to the "Simple UDP" that is a default example in LabVIEW.
(5,674 Views)
I already have file to stream.
Should I use stream out or stream functions to stream?
Thanks!
Vidya
(5,626 Views)
