VISA
Hello..When i'm using VISA application i'm getting error like "VISA polymorphic subVI is broken". I tried running a example VI,but even that is giving the same error. Please help..
Pls note: Right now I'm using Evaluation version of labview..
Thank you,
Sushmith
Message 1 of 10
(4,796 Views)
Hi  sks1990,
                    Which polymorphic subVI is broken?
                    check this:         https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/errors/polymorphic-vi-errors.html
Thanks as kudos only:)
Message 2 of 10
(4,788 Views)
It is not showing which VI is broken. I'm just getting error like"The Poly VI: VISA serial configure port Polymorphic subVI is broken."  This is coming even if i run example VI.
Message 3 of 10
(4,784 Views)
Which example VI are you running?  There are a few...
Does the error message provide a list of VI's leading to or from the one causing the error?
Message 4 of 10
(4,775 Views)
Hi..I'm trying with "Basic Serial write and read".
Message 5 of 10
(4,773 Views)
Did you install NI-VISA? You need NI-VISA to actually run the examples. You can download NI-VISA from the NI Site in the Support section.
Message 6 of 10
(4,759 Views)
I have already downloaded and installed..It was working yesterday,but without doing any changes it started giving error messages...!!!
Message 7 of 10
(4,757 Views)
Accepted by topic author sks1990
Then something corrupted your installation. Did you install something else? Did you uninstall something else? Did you install OS updates? Was there a crash. There could be a million reasons. I would suggest running a repair on your installation of whatever NI software you have installed.
Message 8 of 10
(4,753 Views)
Thank you,will try that and come back..!!
Message 9 of 10
(4,750 Views)
I reinstalled it and its working fine..thank you..!
Message 10 of 10
(4,720 Views)
