VISA resources unseen in MAX
I've been working with LabVIEW for a couple of years and I've generally had no problems connecting devices and using them with GPIB-USB adapter. My computer was recently cleaned and LabVIEW was re-installed. Since then, I've not been able to use my GPIB instruments in LabVIEW. I have Keysight I/O Libraries Suite and when I open it, my instruments are there. However, when I open MAX, I do not see my instruments. I've attached a screenshot of MAX.
Within MAX, I opened VISA Interactive Control, my instruments appear. Here is a screenshot of this:
I cannot access my GPIB instruments within LabVIEW. I'm not sure how to proceed from here.... Thanks for any help.
(2,625 Views)
When you install LabVIEW, you should encounter a dialog box containing different modules that you would want to include within your LabVIEW setup. You may need to run the installer again and be sure to check the boxes next to the modules you need.
(2,617 Views)
