VISA error -1073807232
Can anyone advice on the error code below:  how to solve this problem? It happens intermittent.
The program I writing is a simple PEEK and POKE using VISA VI. The program is cover with a while loop and a stop button.
The VI use are:  VISA Peek & Poke(8bit) and VISA map & unmap.
Error:
d-1073807232(hex=0x4000FF80)
Occurred at VISA map address in VMIC_R2.vi
VISA: (Hex OxBFFF0080) The specified session currently contains a mapped window
(3,174 Views)
Can you please post your code. It will be easy to visualize.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,140 Views)
hi Ranjeet Singh
Sorry unable to copy. thanks i have solve the problem...
(3,118 Views)
Then please share your experience & reason.
May be it will be helpful for next time
--Ranjeet
(3,113 Views)
just added the VISA unmap VI and VISA close  VI at the end of my program
(3,105 Views)
