If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
04-15-2014 02:37 PM
I have implemented a PID in labview and it gives me an output variable(numeric). I need to write this output continously in the write buffer of the VISA write function without clicking any botton. I mean I would like it could do it automatically and continously with a fast speed. I have tried many ways but I can´t get the way to do it. I would appreciate any help.
04-15-2014 03:01 PM
04-23-2014 02:00 AM
Hello killernur,
As Dennis_Knuston say, thereis no too much information. Providing more detailed information, attaching the VI or a screenshoot we could help you in a better way.
In any case your problem come from the configuration of the VISA resource. The steps after that are one that Dennis mentioned: the numeric output, format into a string that the instrument understands (i.e. with Format Into String function), and wire that to a VISA Write.
Here there is attached a explained VI with the features that you demand.
If it does not work, don't hestiate to ask again.
If it work remember to rate the answer so other users can use this information.
Hugs!
04-23-2014 04:35 AM
04-24-2014 09:33 AM
Hello artuntun, I opened the file you uploaded and I would appreciate if you could explain me this part. I understand that the first timer returns the value of the millisecond timer and the second one executes the loop each time the millisecond timer is a multiple of 15, right? But I dont understand the substraction what is doing. And for what is used x-y? (FIRST PICTURE)
In my case, I would like that the PID loop execute every 10ms, but I didn´t implement it as you. In the second picture you can see the way I did it but I am not sure if it is right. What do you think?
