VISA Problem
Hi all,
I have tried to start with VISA, at this time serial communication
(COM-Port).
At first i´ve put a VISO open to the diagram then i´ve tried to connect a
resourcename constant and that´s the problem.
LV say something about differend classes... i´m a little confused...
What may be the problem???
MfG / best regards
M.Waschk mailto:waschk@mavd.de
(3,463 Views)
try ASRL1 in lv5.x and ASRL1: in lv6
type is INSTR
greetings from the Netherlands
(3,463 Views)
hmmm....
the constant will not connect.......
when i touch the wire = (connection: class conflict)
MfG / best regards
albert geven schrieb in im Newsbeitrag:
50650000000500000046340000-993342863000@exchange.ni.com...
> type is INSTR
(3,463 Views)
try following.. after placing the VISA open change into wiring mode, right
click at the Resource in terminal and select create constant.
Now you can select the resource you want's to use.
Henrik
Matthias Waschk schrieb in im Newsbeitrag:
994253266.30747@mail.mavd.de...
> Hi all,
> (COM-Port).
> MfG / best regards
(3,463 Views)
Take a look at the examples. They'll show you what's expected.
"Matthias Waschk" wrote in message
news:994253266.30747@mail.mavd.de...
> Hi all,
> (COM-Port).
> MfG / best regards
(3,463 Views)
