04-04-2025 01:20 AM
Hi Seth,
@SeraphimSeth wrote:
Could you throw off your VI, I'd like to see how it works for me.
I didn't save the VI, so you need to recreate it.
Fortunately I designed the VI in a way that shows ALL code… 😄
Can I use the output in the read buffer from VISA Read instead of Build Array?
Sure you can use the VISARead results directly - as long as you read full messages (aka use a TermChar to read full messages)…
Did you watch this video yet?
04-23-2025 01:33 AM
Hi, GerdW
I'm sorry I missed your message.
I've been unwell for a while. I watched the video you sent and thank you for it.
I fixed the issue by soldering the terminals on the pyrometer's contacts, which allowed me to avoid receiving erroneous packets.
04-23-2025 06:55 AM
Ahh, the classic bad contact/loose wire issue. Seen that too many times.
