02-20-2014 10:27 PM
It's a TI/Stellaris hardware and software.
My original post is here Stellaris Virtual Serial Port driver error in Labview
http://e2e.ti.com/support/microcontrollers/tiva_arm/f/908/p/322370/1123916.aspx#1123916
The boards not working are:
1)Tiva Launchpad http://www.ti.com/tool/ek-tm4c123gxl
2) LM4F232 USB+CAN Evaluation kit http://www.ti.com/tool/ek-lm4f232
Both of them are using Stellaris Virtual Serial Port driver.
All the symptoms are identical in mine and James's (original poster) case
Thanks for looking at this.
Jan
03-02-2014 03:41 PM
Hi Dennis,
Did you have a chance to have a look at this issue?
Should I send you a Tiva Launchpad hardware?
or should I ask the guys from TI to do that?
We are trying to use it in a students lab, so it is imoortant for it to be resolved.
Jan
03-02-2014 04:01 PM
02-06-2015 08:07 AM
TI has posted a firmware update to the TIVA board. This fixes thsi issue so it now works with LabVIEW.
Follow this port:
http://e2e.ti.com/support/microcontrollers/tiva_arm/f/908/t/322370#pi239031349=2
You'll need this programmer:
http://software-dl.ti.com/tiva-c/SW-TM4C/latest/index_FDS.html
| LMFlashProgrammer_1613.zip | LM Flash Programmer | 5924K |
11-11-2016 01:12 AM
Thanks for your post...Me too facing same issue.. I have download the latest firmware for tiva board.. But still I cant set 14400 baud rate... Any more trick that works with your case?
11-14-2016 12:53 PM
Hi Sanky,
What versions of LabVIEW, NI-Serial, and NI-VISA do you have installed? Making sure you have the newest drivers that are compatible with your version of LabVIEW is a good first step to take.
Alex C.
Applications Engineering
11-14-2016 03:25 PM
Hi Sanky,
It was a long time ago and since then our students in a lab have no problem at all with serial communication.
Jan
