VIPM
  • I downloaded VIPM but couldn't find it。
  • I repeated it several times, but it didn't work
Message 1 of 8
(3,313 Views)
where did you download VIPM from ?
Try from https://www.vipm.io/desktop/
Make sure you have admin rights to install this (if you are on Windows), also, if you have an anti-virus, pause it while installing.
Epictetus
Antoine Chalons
Message 2 of 8
(3,302 Views)
I had the issue of VIPM not showing the Windows after the splash screen. I removed and reinstalled it from NIPM to fix the issue.
Message 3 of 8
(3,269 Views)
Could you not find the installer after you downloaded it or can you not find the actual executable program after running the installer?
Message 4 of 8
(3,249 Views)
If you did the install and are now looking for it in the start menu, note that it shows up under "JKI" and not under "National Instruments".
I have on rare occasions had problems with it not showing up when I run it but working fine after a reboot.  Make sure you've tried it after a fresh reboot in case you have a similar issue.
Message 5 of 8
(3,236 Views)
I can find it in NI package manager, but I can't find the application file。
Message 6 of 8
(3,218 Views)
It has been downloaded and cannot be reinstalled. I deleted and uninstalled the registry, but it didn't work. Want to clear by restoring factory Settings.
Message 7 of 8
(3,194 Views)
Hi, a few days ago I had issues to intall it after a dowload through a proxy connection. I had to bypass the proxy ( university network)  and everything worked fine.
Massimo
Message 8 of 8
(3,169 Views)
