VIPM package install error 5000
Prior to installing LV2025, I had no issues creating & installing packages via VIPM.  Had LV2018 and LV2021.
After installing 2025 (may be coincidence), I'm now getting an error during package install:
Main Package Name: labview_dddp_cdi v3.0.0.30
Package Name with Error: labview_dddp_cdi v3.0.0.30
Error Message: VIPM could not install the package lib_labview2018_32bit_3dp_cdi-3.0.0.30 .
Error Code: 5000
Error Source: AFEAEF591DB519B82F623DA9DB2CE563 in 3038DFCFFC1E84FF6A69846558361FAD->OGPM Class.lvlib:DE742B1A3DA7CEB4345B3FE8E257C4FD->OGPM Class.lvlib:D36422DF3547F7393D3C11B3047CFDB6->5799AF2EBC47986B726498EB4F8886CE->VIPM Main Window.vi
There were no issues with building the package.
I tried not using the latest VIPM and went back to the 2021.1 and still didn't work.
Does the package have to be built from the same year version of VIPM?
I wouldn't think so because I've built it with newer VIPM version.
I know VIPM isn't NI product but VIPM.io site does not seem to have an active user base.
(2,191 Views)
Accepted by topic author shuttlefan
Must be something in the build spec file between versions.
I went back and created the build spec from scratch and it is now working.
(2,157 Views)
