VIPM Library not showing in function palette
I have downloaded OpenG library from VIPM. But it's not showing in function palette. if I click "show in palettes" option in VIPM then only OpenG library showing in function palette. but if I close and open LabVIEW app, it disappeared again. Not only OpenG library, none of the VIPM library functions is also not showing in function palette.
Can anyone help me?
Kumaresan
(666 Views)
You aren't seeing OpenG because you have not customized the Block Diagram palettes to show it.
  1. Right-click the Block Diagram to open the Palette, then "pin" it by clicking the pin near the word "Functions".
  2. Click the "Customize" Wrench and click "Change Visible Palettes.
  3. You should see "OpenG" in the list.  Click its Checkbox.
  4. Click OK, and see if OpenG is now visible.
(633 Views)
