VIPM LabVIEW 2013
Tambien tuve el mismo problema que todos ustedes y finalmente pude solucionarlo asi...... espero les sirva
Message 11 of 20
(3,072 Views)
I did all the things.....but still i am getting same error....please help me
Message 12 of 20
(3,011 Views)
resolved....
put your IP as well as the "localhost"
please see the attachments
Message 13 of 20
(2,997 Views)
Hi , thank you i resolved this problem thanks to your advice 🙂
jiji
Message 14 of 20
(2,988 Views)
Yes I had the same problem, I connect my Router with Lan, an it works!!! Thank you very much!!!
Message 15 of 20
(2,934 Views)
I got caught up with this problem today.
Here are my two cents:
- I have both a wired and a wireless connection.
- Although for LabVIEW 2012 I am able to connect from VIPM when the machine access list contains only the IP address of the wireless connection, this is not the case for LabVIEW 2013.
- For LabVIEW 2013 I need to add both 'localhost' and the IP address of the wireless connection. The wired connection IP address is optional, since the wired connection seems to be searched only if the wireless IP address could not connect. The safest setting is to have all three addresses listed, in case wireless is not enabled for any reason.
- VIPM seems to refresh its IP address book when it starts. Retrying to verifying a connection from VIPM after an unsuccessful first try, will probably be unsuccessful again, even after one added the necessary IP addresses in the machine access list in LabVIEW. After setting LabVIEW correctly, it is better to close VIPM and restart it. Then from VIPM verify the connection (this will close and open LabVIEW) and it should work fine.
Message 16 of 20
(2,897 Views)
Thanks... This procedure works great for me!!!
Message 17 of 20
(2,791 Views)
yea tried all of this, still not working, Im going to have to reinstall i think
Message 18 of 20
(2,711 Views)
Agree, disabling the wifi, solves the problem 🙂  thanks bob!!
Message 19 of 20
(2,657 Views)
I was able to successfully install only after i switched from Wireliess to Wired Connection. Thank you for sharing your experience.
Message 20 of 20
(2,482 Views)
