VI web publishing for dummies
HI,
To be honest, although I believe I am a experienced LV user, I am not that much familiar with networking, and I couldn't find a "for dummies" guide to publishing VIs, hence the question here. I want to obviously puvlish my front panel so that it is remotely controllable. I am running the VI on a laptop, which is wirelessly connected on the internet, whereas the "index.html" file of the front panel web page is hosted on the university server.
I set the web server to be something like "C:/users/desktop/web", published an index.html file, which I then copied to the virtual drive of the university. When I load the page on a web browser though, although I can read the page, I get the message on box that the vi was supposed to be, that "The server does not support remote panels".
Clearly I am doing something wrong here, or I haven't understood something in the procedure.
Any help is appreciated!
Thank you in advance!
(2,815 Views)
We both are in same boat, but I did pass the first hurdle, do see here and also refer to the link in that post
(2,811 Views)
For the specific error message that you are seeing, review this document: http://digital.ni.com/public.nsf/allkb/C23EF1551D8C52ED86256B140073EE2E
As for starting material, here's one: http://zone.ni.com/devzone/cda/tut/p/id/4791
(2,803 Views)
Thanx for the quick replies!Unfortunately, before posting this question, I had already checked these links, and still didn't manage to work out!
(2,796 Views)
I also had big trouble getting a frontpanel to run on a cRIO 9074. The solution was to move the html-file one level up from \ni-rt\system\www to \ni-rt\system and changing the respective DocumentRoot entry in \niwebserver.conf.
Also this is a known issue (#255627), but there is no official workaround.
(2,760 Views)
