VI to output variable freq. sine wave and synchronous variable phase stobe pulse.
Has anyone ever developed a VI to put out a variable frequency, variable amplitude sine wave from one analog channel with a short duty cycle pulse from a second channel that is synchronous with the sine wave but has control for varying the phase relative to the sine wave?  I need to be able to strobe an LED and visualize the impact that low frequency sound is having on an experimental setup.
(2,441 Views)
Hi Bassist,
That is a very specific example that you are looking for. I checked and I could not find anything quite that specific. In the meantime, I recommend starting with a basic analog output example and modifying it. I would also like to know what hardware you are using for this application in order to determine if you have the features necessary to perform this task.
Hal L.
(2,424 Views)
