VI to display folder contents
I am trying to view the contents inside a particular folder structure. I have managed to do this using the list folder vi. Based on the folder I then select I want to display the contents of that folder.
Example: Display contents of C:/ECU. This folder could contain folders with names like ECU1, ECU2 and ECU3. When I select any of these folders I then want to display the folders contained inside but Im not sure how to do this. Any ideas?
John
(3,624 Views)
Use BuildPath to create C:\ECU\ECU1 from C:\ECU and ECU1…
(3,612 Views)
Just use another List Folder.  What is your ultimate goal here?
(3,602 Views)
I maybe should have given an overview of what im wanting to do here. So firstly I need to be able to select a folder from a list under a certain file structure. I need to zip any log files inside this folders which have the folder name "logfile". Next I need to select a location to copy this folder and its contents to. Could u help me with this?
John.
(3,591 Views)
See how far this gets you.  I just made a simple path control and a button to save the data in the folder to a zip file.
(3,583 Views)
