VI logger crashes when running a task
I am using VI Logger Lite 2.0.1
I have created a logging task, continously sampling 1 analogue voltage channel at 100k samples/s.
When I click on 'test' in the task attributes/aquisition setting part it comes up with a trace of the data.
However when I click 'run task' after a second the program gives the error:
Engine Error!
Error code = -1967362023(0x8abc7019)
Description = Error -1967362023 occured at an unidentified location
Possible reason(s):
Windows GetCommError:  The hex value of this code is x4000.
Interpret it bit-wise as follows:
x4000: serial port VI error
....it then lists about 15 other hex values of error codes their text explaination.
Note:
Other users of the system, sample with near identical settings from igor without any problems
I've also tryed lowing the aquistion rate, but that didn't help.
My setup is as follows:
NI-DAQmx Devices:
NI PCI-6221
System Information:
Operating System(OS): Microsoft Windows XP
OS Version: 5.01.2600
OS Info: Service Pack 2
Processor: Intel(R) Pentium(R) D CPU 3.00GHz / x86 Family 15 Model 6 Stepping 4 / GenuineIntel / 2992 MHz
Number of Processors: 2
Physical Memory: 1,038,404 KB RAM
Drive C:\ 171,993,796 of 244,099,640 KB free
NI Software Information:
NI-DAQmx 8.0.1f0
LabVIEW Run-Time 7.1
Measurement & Automation Explorer 4.0.0.3010
NI-USI 1.0.2
NI-PAL Software 1.10.0f0
VI Logger 2.0.1
LabVIEW Run-Time 8.0
(2,636 Views)
Hi lukejc,
Any user that uses a logging task must have write access to the VI Logger Database. The default database is located under C:\Program Files\National Instruments\Shared\Tagger\database.  Most users won't have write access to this folder.  You need to enable write access to this folder for all users.  You can do this by right-clicking on the folder and select Sharing and Security, click on the Security tab, and select whichever group you're in (most likely the Users group), then check the Write permissions box in the Allow column.
With VI Logger Full, you can create a new databases where all users have read and write access. You do not have the ability to create/manage databases in VI Logger Lite, so you will need to upgrade to VI Logger Full if you wanted to use this solution.
I hope this helps!
- Erik
(2,623 Views)
