Image of cluster
hello, I my App. I need to print several controls into a JPEG file. I am able to use the "Get Image" method (and Get Image Subset VI) with every control except one: a cluster.
Look into the attached VI. Could someone tell me how I could print the complete content of the cluster inside the picture?
Message 1 of 9
(4,927 Views)
Looks like you found a LabVIEw 8.0 bug....
LabVIEw 8.20 is a bit better, because it gets the cluster image. It is still not perfect, because it seems to loose the color information. 😞
Message Edited by altenbach on 10-27-2006 08:50 AM
Message 2 of 9
(4,919 Views)
😞 OK, at least I know that the problem does not come fom the code. It will manage in an other way.
Thanks for your answer
Message 3 of 9
(4,905 Views)
This sounds similar to the Report Geneartion Toolkit bug re:clusters.
I think Daren mentioned this was fixed.
The Background color issue in LV 8.20 may be a new issue.
This worked correctly in LV 7.1.
Ben
Message 4 of 9
(4,899 Views)
Possible work-around is use a decoration >>> flat box as the background of the cluster elements.
Ben
Message Edited by Ben on 10-28-2006 12:42 PM
Message 5 of 9
(4,880 Views)
This bug also casues the method "FP.GetImage to fail with a similar ailment.
It behaves like the cluster container is transparent.
Ben
Message Edited by Ben on 10-28-2006 02:00 PM
Message Edited by Ben on 10-28-2006 02:04 PM
Message 6 of 9
(4,871 Views)
flat box as background does not work on my side, I still get an empty picture...
Thanks for the time you spent on my topic.
I use LV 8.0 (not planning to switch to 8.1 or 8.01).
Message 7 of 9
(4,835 Views)
I failed to indicate that my above mentioned finding apply to LV 8.2
Ben
Message 8 of 9
(4,817 Views)
My apologies for the delay in posting this, but.......
This was reported to R&D (# 43CA7LVB) for further investigation.
Great catch in finding this one, as well as a viable workaround so quickly!
Cheers,
Matt Pollock
Message 9 of 9
(4,737 Views)
