VI in memory
chixu
Member
VI in memory
I just wonder in what kind of situtation the VI will exit memory after running and in what kind of stitutation the VI will stop running but still being used by the caller. For example, does the function" Close LV object reference" will make the VI exit memeory?
Further more, how can i remove VI from memory after it stop running?
6 REPLIES 6
Nadav_Chernin
Active Participant
Re: VI in memory
If you call vi by reference than after using "Close LV object reference" VI exit from memory. If you call vi usually it will be in memory all time caller is runing.
Jeremy Braden
Active Participant
Re: VI in memory
LabVIEW 6.1 ships with an application note entitled "LabVIEW? Performance and
Memory Management". The first part of the document discusses how to use VI profiler but the latter part discusses how memory is managed and how the programmer can make better uses of resources. To find the document goto help and search for "memory management performance", You can also find the document on our web site http://zone.ni.com/devzone/conceptd.nsf/2d17d611efb58b22862567a9006ffe76/732cec772aa4fbe586256a37005541d3?OpenDocument
Jeremy Braden
JeanPierre
Active Participant
Re: VI in memory
A VI is released from memory when a) its Front Panel is closed AND b) no running VI has a reference opened to the VI.
A VI can stay running in memory with its panel closed when it opens a reference to itself. The exeption is in a Run-Time executable, where the apllication quits when all VI Panels are closed.
LabVIEW, C'est LabVIEW
Nadav_Chernin
Active Participant
Re: VI in memory
If VI running by reference node it will be released from memory when it finished even its FrontPanel is opened.
Highlighted
JeanPierre
Active Participant
Re: VI in memory
If the VI is reentrant, I agree that a peculiar instance of the VI is released from memory when the reference is closed but if the Front Panel of a VI is opened obviously that means that the VI is still loaded in memory. You can verify this reading the application property "All VIs in Memory".
Nadav_Chernin
Active Participant
Re: VI in memory
O.K.
