VI able to run while error exists
I have an error because a global variable is not defined, but the VI is still able to run.
(2,375 Views)
Interesting, is there anything funny about this VI? Did you upgrade it from a much older version of LabVIEW?
(2,331 Views)
If you hold Ctrl and press the run arrow, does the VI become broken?
(2,316 Views)
Interesting, but that is a local and not a global (notice the house and not the globe).  Doesn't explain the behavior.
(2,308 Views)
Attach the VI that is doing this so others can try it out!
(2,295 Views)
Right, local, sorry.
(2,284 Views)
Unfortunately, when I tried to select an object for the local variable to link to, LV crashed.
Next time when I opened the VI it showed the error correctly.
It was a VI developed few days ago, think I saved it initially with the error, I don't remember, LV 2016, so I think it's not very important.
(2,280 Views)
