VI Server
Hi
What is VI server ? Is it just like calling a sub vi and controlling its properties from the main VI (high level Vi).
Why and where we used VI server?
What are its advantage ?
Please reply as soon as possible.
it is very urgent for me to know all these.
Raman
(3,957 Views)
There are a number of application notes and examples found here
http://zone.ni.com/devzone/devzone.nsf/webcategories/0C9B048BCF3AF60486256AB7006B3729
that may help you.
Regards
Ray Farmer
Regards
Ray Farmer
(3,954 Views)
Raman,
I am having one article from NI website. This would help you get in more.
(3,946 Views)
Hi Ray
Thanking you for reply.
But that link does not give me the answer i am looking for.
So please explain little more because i haven't used VI server.
Bye
(3,937 Views)
Maybe you should read the help files from LabVIEW.
Try that and then have a look at some examples (also shipped with LabVIEW).
If you don't have LV installed or available then it's going to be really hard to explain it to you.
The simple version is that it's like programatically accessing properties and methods of LV objects from anywhere within LV.
Of course it's more detailed than that, but to learn properly, you should read the help and study the examples.
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(3,926 Views)
Sorry about that, I would have thought the first two links , 'Calling a VI by reference' and 'Cloning Front Panel....' should go a long way to explaining things plus the document supplied by ii.
But basically, it a way of controlling a VI dynamically, thats is loading into memory, setting front panel settings, running the VI, obtaining values from the VI, and so on.
One advantage is the VI doesn't have to be in memory until its required and then it can be unloaded when it finished with.
Hope this helps.
Regards
Ray Farmer
Regards
Ray Farmer
(3,923 Views)
